How to use PLEG to invoke HTTP command
I have trying to find a solution to a setup.
My setup will be I will have an IP Camera that can send HTTP commands based on motion. I then want it to turn on backdoor patio lights.
I want to use the Camera Motion Detection to be like my PIR.
I know the command to run and it calls a scene and executes fine.
http://192.168.xxx.XXX:xxxx/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=55”
I need to add logic so it runs on a schedule after sunset and before sunrise.
Can someone give me an example how to set this up as i do not see an option for scenes in PLEG under Triggers or Conditions.
Get the camera to toggle a virtual switch instead.
Use the virtual such as a pleg trigger.
Agree - there are threads about how to setup a virtual motion detector using http from a camera.
