How to use a 'IS NOT' / '!=" statement?
What command do I have to use for a 'if not" statement?
I now use
if (value == "string") or (tonumber(value) == int) then..
but sometimes i would rather want to use a IS NOT statement which is sometimes much easier as:
if (value != "string") or (tonumber(value) != int) then..
it seems ‘!=’ does not work, so the question is: how to do a “IS NOT” in lua code?
Everything you wanted to know about the LUA language: http://www.lua.org/
The site does not cover Vera specifics of course, but does a good job with the language itself.
