No, Ergy plugin is not listed in my installed apps, so i can uninstall it. But i have an error message on it
For the Luup problem, an other french user use scripts and plugins without problem on UI5. The only difference with me is that he don’t try to install the ergy plugin.
@garrettwp and @cedriclocqueneux, I have noticed that when you uninstall an app it seems to just 1. remove the app related device and 2. remote the app from the list of installed apps but does not actually remove any of the plugin files from /etc/cmh-ludl?
But the Ergy[200] message makes it look like you have an Ergy device #200 that you could delete under devices?
For this i’ll must downgrade to UI4, i don’t have backup before Ergy Plugin, it was installed immediatly after the update in UI5. And i have fix lots of problems on this version, i don’t want to make all these a new time No other solution ? Where is the update of this plugin announced yesterday ?
