How to synchronize output listing on Vera?
I haven’t worked with the plugin in ages since setting everything up, but today decided to make some changes to my entry system. Since the Elk and Vera have very shoddy communication (ie.- Elk Tasks do not trigger anything, counters don’t seem to be communicated, etc.), I have worked around the limitations by using phantom outputs on the Elk to trigger events on the Vera. The problem I am having now is that I forget how to relay the setup changes that I’ve made to my outputs on the Elk using “Elk RP” on my PC. It seems that toggling visibility and changing their names does not take effect on the Vera, even after several reboots.
Can someone tell me what I need to do? Thanks in advance!
