How to set up a custom IR device?
Hi folks!
New VeraLite user here.
I have sort of an oddball A/V processor that I’d like to control using Vera and GlobalCache GC100. The processor is an Emotiva UMC-1. Naturally, if I just go to add an A/V device, Emotiva is nowhere in those drop-down menus.
A full list of Pronto codes is available here: http://emotiva.com/umc1/remoteCodes_1-25-11.pdf
GC100-12 IR port 1 is connected directly to IR input jack on the A/V processor using a 1/8" mono cable. Using Premise Home Control, I was able to get the GC100 to turn the UMC-1 on and off, change volume and inputs.
GC100-12 is added to the Vera. The 6 IR blaster ports are available in the drop-down menu.
So… what do I do now? Is there a generic “Receiver” XML template where I fill in the make and model, and paste the Pronto codes into? At what point does Emotiva appear in the drop-down list for receivers?
Thanks in advance,
Alex
There are some files in this thread that you can edit:
http://forum.micasaverde.com/index.php?topic=4542.msg24677#msg24677
Once you have edited the pronto codes in and renamed the two files to something like I_Emotiva.xml and D_Emotiva.xml, upload them in the apps area > develop apps >luup files area, and then create a device using the file names.
You then just need to associate your IR transmitter from the newly created devices settings tab.
Sweet!
Thank you very much. I’ll give it a shot tonight.
Did this help ? I am possibly interested as I have Emotiva MC-700.
