Please
how to set a notification based on watts consumption with an158 (ES)
I get only notification for turn off or on
Connected to Vera I have a CurrentCost device which measures current and I use the Virtual Switch plug-in to monitor the current value and set a switch when the current exceeds a certain value. I can then use this switch to trigger scenes etc.
Hi clairedenys,
I am assuming that the AN158 actually reports power, and that you can see it on the dashboard. If not, then you can stop here.
How I would do this:
- Install the Combination Switch plugin from apps.mios.com.
- Create a Combination Switch device (or configure the one that was auto-created).
- Go to the Configuration tab and set it up like the first screenshot (100 W to infinity in this example).
- Set up a notification like in the second screenshot.
You can also use the EMS plugin which is know to work with AN158.
http://forum.micasaverde.com/index.php/topic,11076.msg78891.html#msg78891
[quote=“futzle, post:3, topic:174006”]Hi clairedenys,
- Set up a notification like in the second screenshot.[/quote]
THANKS
sa marche tr?s bien!
