cw-kid
1
You use to be able to see all your Vera scenes in the Google Home app in the settings.
I cannot figure out how to do this now in the Google Home app ?
I have exposed a new Vera scene to Google Home via the https://nexus.getvera.com portal.
I created a new routine in the Google Home app, to have an action to “run scene name”.
However when I run this routine in the Google Home app, my Vera scene is not run by assistant.
I have told assistant to “update devices”.
cw-kid
2
I’ve got it working now, Its the buggy Vera portal for Google Home settings.
If you click into the box on the right side to set a custom name, it then auto unchecks the tick next to that same scene for some daft reason.
I looked in there again and noticed my scene was not ticked and therefore not exposed to Google Home.
However I was still unable to see in the Google Home app / Assistant app settings where it lists all the Vera scenes its imported.
Seems you cannot do that anymore.
