How to reset a Fibaro switch or a Fibaro dimmer.
I had to reset all my switches, sensors and dimmers. The problem with the Fibaro devices was that the procedure written down in their manual is not functioning. I write an email to Fibaro and got the next answer.
Procedure of resetting of FIbaro DImmer and Relay Switch it :
  1. Turn off powe supply,
  2. Hold B button
  3. While holding B button, turn on supply
  4. Hold B button for 5 sec (In relay you should hear click sound)
  5. Release button and turn off and onn power supply.
This procedure is working properly and rule 5 is very important.
