How to rediscover deleted device?
By mistake I have deleted a couple of devices from the rfxtrx controller. I dont want to restore from backup since I have made a lot of other changed in my Vera setup since last backup.
How do I get rfxtrx to rediscover my deleted devices? It is already set to Autodetect.
(Vera Edge, Rfxtrx controller beta3)
They will be detected like the first time they were detected, that is automatically if the device is delivering regular data to the RFXtrx or when you will send a command or you should create them manually through the UI like the initial time.
So it depends on the type of device.
The devices I deleted was thermometers (WT450H ESIC / Clas Ohlson). The ones I didnt delete is still working. But I cannot get the ones I deleted to be rediscovered/recreated. Any advice other than restore backup or reinstall the plugin?
Did you maybe use the “Delete selected devices & prevent automatic creation”-option under “Managed devices”?
If so, delete the entry under Advanced → Variables → DisabledDevices. Refresh. It will then auto detect when “hearing” the temperature sensor for the first time.
