how to read temperatures from one wire owserver on linux box?
Hi , I’m new ;D
have some home automation devices but finally started to use veralite as the main one.
I have owserver running on linux (openwrt router) I would like to read those temperatures from vera.
plugin for EDS box is not working, when i put the IP and port (which looks like is the same on both devices 4304) it do not find any sensors.
any help?
You need to push readings from owserver to vera variables plugin. It works really nice this way. Just write cron script that will push data every 5 minutes and you have it.
