I got the CI800/CT80 Z-Wave thermostat with Verlite UI6. I use “Sense” to program the daily program like Wake, Leave, Return and Sleep. I just wondering if there is a easy way to program “Hold” and “Vacation”? If I use sense to set “Hold” and “Vacation” temperature, what can I do to stop the daily program being triggered to override my set temperature?
I know I can go to “Advanced setting” and manually “Disabled” (unchecked Enabled) for each daily sense. And do the whole thing again when I want to un-hold or return from vacation. But this is so manual work and involve so many steps. Compare to the old way of pushing one button on the panel which I can’t do anymore as CT80 disable this on the panel when I connect to Z-Wave. Any suggestion?
