I recently bought Vera Edge. So for Initial testing a bought AEON Multisensor 6 (zw100-c) along with the Hub. But this sensor is not included in the device list.
Could anyone help me how to pair AEON Multisensor 6 (zw100-c)?
And also how to check the Firmware version in both the Hub and the sensor? Thanks.
Update: I went through the below process several times. When I would change the Generic I/O device, data from the other sensors wouldn’t show up in vera or imperihome. After unpairing and repairing the sensor several times I gave up and went to sleep. When I went to sleep only the motion sensor seemed to work. When I woke up vera and imperihome were displaying data for the other sensors. I definitely wouldn’t recommend starting with this sensor.
I’m currently attempting to pair a Multisensor 6 without much luck. I’ve been able to get the temp, lux, and humididty to show up but seem to be missing something on the motion sensor. I have about 10 zwave devices and an android tablet running imperihome and this sensor is the only one to have me scratching my head (I’m sure I am missing something super obvious though). I’m using vera lite with UI7
I found this online.
1. Bring the MultiSensor close to your hub and add it to your Vera choosing the 4-in-1 sensor as device type and single-clicking on the action button. It will come up as a "D_GenericIO1" device. You may have to exclude it first (simply send an unpairing command from your Vera and click on the MultiSensor?s action button - read more here).
Once the device is included, please wait for all children nodes to show up. Then press the action button quickly 3 times to put the device in the wake up mode. DO NOT hold the action button. The LED indicator on the sensor should blink - do not press anything else on the sensor at this point.
Select the new device, then click on Advanced.
Go to the Params tab and make the following changes:
