How to make Vera recognize your USB-to-Serial Adapter
(in this example I’ll take in consideration the and FTDI adapter)
  • login into your Vera command line
  • run dmesg > /tmp/dmesg-pre
  • plug your adapter into Vera’s usb port
  • run dmesg > /tmp/dmesg-post
  • run diff -u /tmp/dmesg-pre /tmp/dmesg-post
    you shoudl see something like this
-usb.c: new device strings: Mfr=1, Product=2, SerialNumber=3 -usb.c: USB device number 5 default language ID 0x409 -Manufacturer: FTDI -Product: USB FAST SERIAL ADAPTER -SerialNumber: FT48DXER -usb.c: unhandled interfaces on device -usb.c: USB device 5 (vend/prod 0x403/0x6010)[b] is not claimed by any active driver[/b].
“is not claimed by any active driver” means that on Vera are no drivers that are for your device. In generally this are only new devices with another product code, which aren’t known by the old driver but are working with it.
In this case we need the ftdi module which is ftdi_sio
  • remove the module: rmmod -f ftdi_sio
  • add the module and make it to claim your device: insmod vendor=0x403 product=0x6010
  • run: dmesg > /tmp/dmesg-post2
  • diff -u /tmp/dmesg-post /tmp/dmesg-post2
    if you see something like this:
+hub.c: new USB device 00:03.1-1.2, assigned address 5 +usb.c: kmalloc IF 806febc0, numif 1 +usb.c: new device strings: Mfr=1, Product=2, SerialNumber=3 +usb.c: USB device number 5 default language ID 0x409 +Manufacturer: FTDI +Product: FT232R USB UART +SerialNumber: A9003Pjc +usbserial.c: FTDI FT232BM Compatible converter detected +usbserial.c: FTDI FT232BM [b]Compatible converter now attached to ttyUSB0 (or usb/tts/0 for devfs)[/b] +usb.c: serial driver claimed interface 806febc0 +usb.c: kusbd: /sbin/hotplug-call add 5
it means that your adapter was recognized and attached to ttyUSB0
  • if you want that the adapter to be recognized again after reboot you’ll have to do this also:
    echo “ftdi_sio vendor=0x403 product=0x6010” > /etc/modules.d/65-usb-serial-ftdi
IF YOU FIND THAT THIS IS WORKING FOR YOUR ADAPTER PLEASE PASTE ON THIS THREAD IT’S KERNEL MODULE, VENDOR AND PRODUCT CODE SO I COULD ADD THEM BY DEFAULT IN THE FIRMWARE.
Still having trouble. I should have two usb serial ports, but vera only show one port for configuration.
From dmesg
Manufacturer: FTDI
SerialNumber: FT5LTOAF
usbserial.c: FTDI SIO compatible converter detected
usbserial.c: FTDI SIO compatible converter now attached to ttyUSB1 (or usb/tts/1 for devfs)
usb.c: serial driver claimed interface 81cfe4a0
usbserial.c: FTDI SIO compatible converter now attached to ttyUSB2 (or usb/tts/2 for devfs)
usb.c: serial driver claimed interface 81cfe4b8
From /proc/tty/driver/usb-serial
root@HomeControl:/proc/tty/driver# cat usb-serial
usbserinfo:1.0 driver:v1.4
0: module:cp210x name:“CP210X” vendor:10c4 product:ea60 num_ports:1 port:1 path:usb-00:03.1-1.1
1: module:ftdi_sio name:“FTDI SIO compatible” vendor:0403 product:6010 num_ports:1 port:1 path:usb-00:03.1-1.2
2: module:ftdi_sio name:“FTDI SIO compatible” vendor:0403 product:6010 num_ports:1 port:1 path:usb-00:03.1-1.2
root@HomeControl:~# ls -lh /dev/usb/tts/
crw------- 1 root root 188, 0 Jul 12 18:34 0
crw------- 1 root root 188, 1 Dec 31 1969 1
crw------- 1 root root 188, 2 Dec 31 1969 2
This device should have two serial ports, however vera only shows one port for configuration.
My new [Bytecc] Serial Portal isn’t working correctly either. I can see it being claimed, and allocated, but the serialProxy isn’t displaying it in the Vera UI:
usb.c: kmalloc IF 81743ea0, numif 1 usb.c: new device strings: Mfr=1, Product=2, SerialNumber=0 usb.c: USB device number 6 default language ID 0x409 Manufacturer: Prolific Technology Inc. Product: USB-Serial Controller usbserial.c: PL-2303 converter detected usbserial.c: PL-2303 converter now attached to ttyUSB2 (or usb/tts/2 for devfs) usb.c: serial driver claimed interface 81743ea0 usb.c: kusbd: /sbin/hotplug-call add 6
From /proc/tty/driver/usb-serial:
root@HomeControl:/etc/cmh# cat /proc/tty/driver/usb-serial usbserinfo:1.0 driver:v1.4 0: module:cp210x name:"CP210X" vendor:10c4 product:ea60 num_ports:1 port:1 path:usb-00:03.1-1.1 1: module:ftdi_sio name:"FTDI FT232BM Compatible" vendor:0403 product:6001 num_ports:1 port:1 path:usb-00:03.1-1.2.3 2: module:pl2303 name:"PL-2303" vendor:067b product:2303 num_ports:1 port:1 path:usb-00:03.1-1.2.4
root@HomeControl:/etc/cmh# ls -lh /dev/usb/tts/ crw------- 1 root root 188, 0 Aug 3 18:09 0 crw------- 1 root root 188, 1 Aug 3 18:06 1 crw------- 1 root root 188, 2 Dec 31 1969 2
The device is a Bytecc BT-DB925 (listed as Product # 2067 on Monoprice.com). I’m on build 807, the other device (recognized correctly) is my Alarm panel interface.
Following the work-around instructions in http://forum.micasaverde.com/index.php?topic=1170.60, the extra Serial port is recognized in Vera’s UI (barring a bug in [tt]serproxy[/tt] itself not starting, which I’m about to go file). My [tt]serproxy.ports[/tt] file now looks like:
root@HomeControl:/tmp/log/cmh# cat /etc/cmh/serproxy.ports vendor:067b product:2303
Is this the same?
http://www.dealextreme.com/details.dx/sku.8757
It looks similar, but the one you reference is listed as made by “HL” with a Part# of USB-RS232. There doesn’t appear to be much information on the manufacturer of that one, nor it’s drivers. With the Bytecc, I could find more information, and positive reviews on the drivers, so I was willing to blow $9 (plus taxes, shipping) to give it a go :wink:
I figured we could all use a few low-cost options for RS-232/USB for dealing with the HA of the Home Stereo (TV, Amp etc). My [Panasonic] TV has Ethernet, but they didn’t think to give is HA over it’s Ethernet, so it’s also got RS-232.
Device: APC Back-UPS ES 750, Direct USB Interface (APC Proprietary cable)
lsusb output (filtered to the device in question)
Bus 002 Device 007: ID 051d:0002 American Power Conversion Uninterruptable Power Supply
It reports itself in dmesg as the following:
[code]usb.c: skipped 1 class/vendor specific interface descriptors
usb.c: new device strings: Mfr=3, Product=1, SerialNumber=2
usb.c: USB device number 7 default language ID 0x409
Manufacturer: APC
Product: Back-UPS ES 750 FW:819.z2.D USB FW:z2
SerialNumber: AB0546142379
usb.c: USB device 7 (vend/prod 0x51d/0x2) is not claimed by any active driver.
Length = 18
DescriptorType = 01
USB version = 1.10
Vendor:Product = 051d:0002
MaxPacketSize0 = 8
NumConfigurations = 1
Device version = 1.06
Device Class:SubClass:Protocol = 00:00:00
Per-interface classes
Configuration:
bLength = 9
bDescriptorType = 02
wTotalLength = 0022
bNumInterfaces = 01
bConfigurationValue = 01
iConfiguration = 00
bmAttributes = e0
MaxPower = 0mA
Interface: 0
Alternate Setting: 0
bLength = 9
bDescriptorType = 04
bInterfaceNumber = 00
bAlternateSetting = 00
bNumEndpoints = 01
bInterface Class:SubClass:Protocol = 03:00:00
iInterface = 00
Endpoint:
bLength = 7
bDescriptorType = 05
bEndpointAddress = 81 (in)
bmAttributes = 03 (Interrupt)
wMaxPacketSize = 0006
bInterval = 0a
[/code]
Shutdown (“kill”) [tt]serproxy[/tt], [tt]ser2net[/tt], [tt]Start_serproxy.sh[/tt] to allow me to [tt]rmmod[/tt] the existing [tt]ftdi_sio[/tt] driver since, in my case, it was “in use” by another USB Device and failed [tt]rmmod[/tt].
Force the claiming of the device using:
insmod ftdi_sio vender=0x51d product=0x2
CJ: Can you tweak your instructions above to include some of these?
It then gets claimed, but bad things start happening (I used “[tt]cat /dev/usb/tts/3[/tt]” for grins):
[code]usbserial.c: FTDI SIO compatible converter detected
usbserial.c: FTDI SIO compatible converter now attached to ttyUSB3 (or usb/tts/3 for devfs)
usb.c: serial driver claimed interface 813ec280
ftdi_sio.c: v1.3.5:USB FTDI Serial Converters Driver
usb_control/bulk_msg: timeout
ehci-q.c: clear tt 00:03.1-1.2 p1 buffer, a7 ep0
ftdi_sio.c: ftdi_set_termios FAILED to set databits/stopbits/parity
ftdi_sio.c: ftdi_set_termios urb failed to set baurdrate
ftdi_sio.c: urb failed to clear flow control
ftdi_sio.c: ftdi_open Error from DTR HIGH urb
ftdi_sio.c: ftdi_open Error from RTS HIGH urb
Unable to handle kernel paging request at virtual address 00000010, epc == c025c4c4, ra == c025c4bc
Oops in fault.c::do_page_fault, line 206:
$0 : 00000000 1000fc00 818aee00 00000000 00000019 00000000 0000001f 8111f2a0
$8 : 00000000 00004e94 00004001 00004e63 801b0000 801b0000 801b0000 0000004d
$16: 81770820 00000001 81770800 806aa000 00000001 00000000 c0240000 803e3660
$24: 00000010 8002da48 804fe000 804ffd50 0040bfbc c025c4bc
Hi : 00000000
Lo : 00000005
epc : c025c4c4 Tainted: P
Status: 1000fc03
Cause : 0000000c
PrId : 00029029
Process cat (pid: 2068, stackpage=804fe000)
Stack: 0000bc03 c025e264 8105b0c0 8105b0c8 00000000 00000000 804ffda0
00000000 000001f4 804ffdc0 806aa000 806aa000 c0242b38 806aa000 0000bc03
00000000 812b67c0 0000000c 00000003 800987b4 81d0a8a0 00000009 81770800
81770820 81770800 c023fea8 81c512e0 00000000 00000000 806aa000 ffffffed
00000000 803e3660 00002000 812b67c0 801b2720 00409e8c 00000002 8009ac4c
8009ac18 …
Call Trace: [] [] [<800987b4>] [] [<8009ac4c>]
[<8009ac18>] [<80043584>] [<800284a0>] [<8009a3d8>] [<8009a3bc>] [<80044358>]
[<8006bbac>] [<800447ec>] [<800447d4>] [<8000b484>] [<8000b420>] [<80037180>]
[<800372e0>] [<80037578>] [<8003769c>] [<80008a60>] [<8000f330>] [<8005bb6c>]
Code: 24a5e264 8e030020 8e420004 8e440004 92030024 8e050020 8c820000 8c840014
[/code]
The device is not FTDI-based, have you tried to force-claim it using other drivers: PL, etc?
Not yet, but I have a scary feeling I really need to load [tt]apcusbd[/tt], from the OpenWrt dist, into Vera. If it’s going to be a different type of device (a USB HID) then it may not work with any Serial driver.
If that’s the case, it puts us squarely back at this issue:
[url=http://forum.micasaverde.com/index.php?topic=1428.0]http://forum.micasaverde.com/index.php?topic=1428.0[/url]
which was never answered…
Just tried another serial adapter, supposedly PL-2303.
Received “usb.c: unable to get device descriptor (error=-32)”. Error 32 means “stall”, and some googling shows it’s not an unusual thing, often caused by OHCI-EHCI conflict.
One guy found that one of most likely reasons is one of the devices in OHCI chain is attempted to be initialized as EHCI, which causes timing problems so “ehci” device can’t be read. He managed to turn that erroneous device into OHCI manually, and everybody was happy ever after.
I did nitice few ehci-related messages in dmesg before the error messages…
Any idea on how to do or what to check here?
UPDATE: This might be important - very same adapter recognized perfectly well on Asus 520GU with Kamikaze. How possible? Old drivers on Vera?
It’s sticky not for replies, but as a source of valuable information.
I’m in the same boat as 325xi, when I just tried connecting a USB-to-RS232 serial cable.
Oddly enough, the cable is SKU #8757 sold by DealExtreme (cheap!), but my PC kept wanting to give it Prolific PL-2303 drivers … so I’m guessing that’s what it is.
@325xi, did you ever get this cable working with Vera?
My poking around with DMESG (per cj’s instructions, above) was confusing, and I also see the “usb.c: unable to get device descriptor (error=-32)” line you cited.
Could use some guidance here.
The one that actually works is SKU 5947, but it kinda defeats the point of getting the thing from there.
I tried two other types and some work with Asus 520gu, but not Vera, some work with none (same error as you got) - but all seem to work with Windows. I don’t know what’s the trick, and the guy who might possibly shed some light on this is apparently too busy…
Thanks, 325xi, I didn’t expect good news on this issue. In fact, with my 2412S (serial) PLM arriving in a couple of days, I’ve been regretting my too-cheap-to-be-good purchase of this USB-to-RS232 cable from DealExtreme (Hong Kong). Back to the drawing board, and more $$$ likely!
I wanted to follow up by saying it was a waste of time and money to buy the USB-to-serial adapter cable (#8757) from DealExtreme. None of the included Windows drivers play nicely with it in Windows XP, and plugging the cable into Vera yields NOTHING useful in the DMESG report (see first posts of this thread).
I’m going to throw away this cable, and (grumble, grumble) go buy the one from Future Technologies that I should have bought in the first place. :-/
Meahwhile, my brand-new 2412S sits in the corner, waiting, waiting…
LibraSun,
I also built this out to "retain’ the collective knowledge in this thread.
http://wiki.micasaverde.com/index.php/Serial_Supported_Hardware
It’s small now, but can be grown. Can you add your device to the list to indicate it’s specifically not working so others dont fall in the same pit-trap?
@325xi, you might want to do the same…
I’d certainly love to augment your (great, by the way!) wiki page, but…
…I’m not 100% certain my cable isn’t faulty. I mean, how many products register themselves as Mfr. code 000 and Dev. ID 000 in Windows, and refuse ALL of the drivers contained on their own mini-CD?
So, I’m still trying to resolve whether I’m dealing with a broken product, or just a poorly documented one. Once I’m convinced either way, I will update your table(s). THANKS!
I just update wiki with my experience with the adapters… Vera seems to be more sensitive then plain Kamikaze - I suspect a bit outdated drivers…
@CJ, I borrowed the 8-Port USB-Serial adapter from @nanckekr that he was trying to get working back in June/July. It was discussed in this thread:
http://forum.micasaverde.com/index.php?topic=1170.45
and I’d previously created a placeholder for the device in the Serial USB Wiki page:
To make it work cleanly out of the box with Vera, there are a few things to be sorted:
a) Default install should pre-configure the [tt]/etc/modules.d/65-usb-serial-ftdi[/tt] file
You reference this in the first post, but it doesn’t appear in the Default Vera build (1.0.980), so folks have to manually add with the command line interface to get this device recognized.
Here is the default setting for this file in 1.0.980:
    ftdi_sio
and here’s what’s needed to make it recognise this USB-Serial controller:
Can you add this to the standard image so folks don’t need to add it manually?
b) “id” code in [tt]serproxy[/tt]/[tt]ser2net[/tt] creates duplicate labels
This device has “Dual” UARTs per USB entry, which shows as follows in the [tt]lsusb[/tt] listing:
... Bus 001 Device 006: ID 05e3:0604 Genesys Logic, Inc. USB 1.1 Hub Bus 001 Device 007: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC Bus 001 Device 008: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC Bus 001 Device 009: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC Bus 001 Device 010: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC
Unfortunately [tt]serproxy[/tt]/[tt]ser2net[/tt] then goes and creates “duplicate” id values as can be seen in the following log:
[tt]11/28/09 17:14:05 ==Found Serial Port: 1 path:/dev/usb/tts/2 name: ftdi_sio id: usb-00:03.0-1.2.4.1
11/28/09 17:14:05 ==Found Serial Port: 2 path:/dev/usb/tts/3 name: ftdi_sio id: usb-00:03.0-1.2.4.1
11/28/09 17:14:05 ==Found Serial Port: 3 path:/dev/usb/tts/4 name: ftdi_sio id: usb-00:03.0-1.2.4.2
11/28/09 17:14:05 ==Found Serial Port: 4 path:/dev/usb/tts/5 name: ftdi_sio id: usb-00:03.0-1.2.4.2
11/28/09 17:14:05 ==Found Serial Port: 5 path:/dev/usb/tts/6 name: ftdi_sio id: usb-00:03.0-1.2.4.3
11/28/09 17:14:05 ==Found Serial Port: 6 path:/dev/usb/tts/7 name: ftdi_sio id: usb-00:03.0-1.2.4.3
11/28/09 17:14:05 ==Found Serial Port: 7 path:/dev/usb/tts/8 name: ftdi_sio id: usb-00:03.0-1.2.4.4
11/28/09 17:14:05 ==Found Serial Port: 8 path:/dev/usb/tts/9 name: ftdi_sio id: usb-00:03.0-1.2.4.4[/tt]
These Id’s are used by Vera in the Serial Port’s “Device Number” field in Vera. Since they’re not unique, Vera only “sees” this as a 4-Port serial device, not an 8-Port device. (See attached screenshot)
c) Plugging this device in, with the above issues, results in loss of connectivity to the ZWave dongle
The devices appear to be claimed correctly by the FTDI drivers, and there’s nothing in particular in dmesg to indicate a problem, but if I boot with the device connected, then the other Serial devices (my Alarm Panel, and the ZWave dongle) both seem to drop out. They show in device listings (Etc) but Vera has problems communicating with them.
I suspect it relates to the duplicate Id’s in (b) above, but can’t tell.
For now, it’s unplugged. Ping me offline directly if you want to debug it more directly on Vera and I’ll plug it in. I’d like to get this (or it’s 4-port equiv) working to help with folks who want direct-wiring of their Media Devices (Amp, TV) and Blinds.
Manufacturer: B&B Electronics
Product: Model 485USBTB-2W
SerialNumber: BBR7EC7C
usb.c: USB device 4 (vend/prod 0x856/0xac33) is not claimed by any active driver.
Length = 18
DescriptorType = 01
USB version = 2.00
Vendor:Product = 0856:ac33
MaxPacketSize0 = 8
Device version = 6.00
Configuration:
bLength = 9
wTotalLength = 0020
bNumInterfaces = 01
iConfiguration = 00
bmAttributes = 80
MaxPower = 100mA
Interface: 0
bLength = 9
bNumEndpoints = 02
bInterface Class:SubClass:Protocol = ff:ff:ff
iInterface = 02
Endpoint:
bLength = 7
bmAttributes = 02 (Bulk)
wMaxPacketSize = 0040
bInterval = 00
Endpoint:
bLength = 7
bEndpointAddress = 02 (out)
bInterval = 00
usb.c: kusbd: /sbin/hotplug-call add 4
Bus 001 Device 004: ID 0856:ac33 B&B Electronics
insmod ftdi_sio vendor=0x856 product=0xac33
[quote=“guessed, post:18, topic:164602”]@CJ, I borrowed the 8-Port USB-Serial adapter from @nanckekr that he was trying to get working back in June/July. It was discussed in this thread:
    ftdi_sio
For now, it’s unplugged. Ping me offline directly if you want to debug it more directly on Vera and I’ll plug it in. I’d like to get this (or it’s 4-port equiv) working to help with folks who want direct-wiring of their Media Devices (Amp, TV) and Blinds.[/quote]
I’'l add it to the wiki- but wanted to let the powers that be know that the this 4-port model comes up fine to be configured by the vera UI.
http://www.mcmelectronics.com/product/83-10137
I happened to have it floating around from my old homeseer system also.
just plugged it in.
I saw a post that the to kick things over have to hit save or reboot. SO I hit save. Vera took loingerthan usual to come back. when it came back up i went into serial configuration and all looks well.
