Along with supporting vera’s from remote, I also have to do some other stuff. I want to know if it is possible for vera to somehow tell me what it’s external IP is.
The forwarding from mios seems to mask the IP.
Thanks!
Thanks!
Appears not to work. Fails to return a .JPG image so I tried the luup code and that borked vera.
Will need to go onsite to reboot.
You would think vera could have on any screen the arfing external IP!
Linking to correct code (for now
