[How To] Fix bug 1481
Howto fix (minor) bug 1481 -thanks to MCVFlorin-
0001481: missing logo in “add devices” section.
Even though its a very minor bug, this requires some user interaction if you want it solved (like i did).
referring to http://bugs.micasaverde.com/view.php?id=1481
As Vera doesn’t support patching, fixing this requires replacing a file.
Here are the steps:
  1. Download the attached file.
  2. Rename the file to “cpanel_data.js”
  3. SSH into Vera.
  4. Delete /www/cmh/js/ui3/cpanel_data.js
  5. Copy the file (renamed) I attached to /www/cmh/js/ui3/
please use a program like WinSCP or SCP (depending if you are on a windows client or a linux based client).
WinSCP can be found here: WinSCP :: Official Site :: Free SFTP and FTP client for Windows
Please note that VERA does not support SFTP so you will need to select SCP as protocol.
–edit—
attached the correct file
I’m confused as to which file your reference to, I do not see an attached file. thanxs Mike
Be sure you are logged into the forum, (you see your name at the top of the page) to see the attachment…
Also to use WinSCP set port to 22, User name to root (all lower case) and Protocol to SCP. For password use the one on the sticker on your Vera. Hope that helps.
@henk, I’ve download the zip file but am unable to open I get an error message tried several times with no success, more clues please… Mike
[quote=“Henk, post:1, topic:168342”]Here are the steps:
1.
3.
4.
5. Copy the file (renamed) I attached to /www/cmh/js/ui3/[/quote]
@Michael_N_Blackwell;
please do not attempt to unzip the file, ONLY rename is as per my instructions above!
Helps if one would only read the instructions ;D thanxs Mike
