Let’s say turn on outside lights then wait 10 minutes
Then execute sunset scene.
I dont know much about pleg or Lua scripting so an example would help
You could download the virtual switch add on and then you could tell scene 1 to delay the 10 minutes and turn on virtual switch 1.
Then use virtual switch 1 as trigger to trigger sunset scene. You can always use it as an additional trigger if you have existing trigger on the scene already.
Thank you
I will give it a shot
[quote=“MKarlyle, post:1, topic:198948”]Let’s say turn on outside lights then wait 10 minutes
I dont know much about pleg or Lua scripting so an example would help[/quote]
The countdown plugin would be the ticket, and it means you can stop/cancel the scene running if necessary. You don’t need any code.
Also, take a look at the DelayLight plugin: http://forum.micasaverde.com/index.php/topic,60498.msg351460.html#msg351460
