How to disable Schlage keypad at night?
I’m a new customer of Vera 3 and have a Schlage lock that I was using with Nexia before. I has set it up to disable the keypad at night and enable in the morning. I think it may have been vacation mode. Is there a way to do something similiar with Vera?
I guess the other way to do this is to restrict the codes to certain times of the day. Does anyone know how to do this with the Schlage locks. I really don’t want anyone to be able to use ANY codes at night. (11pm - 6am)
Not sure if you figured it out already, but the vera interface allows you to apply daily restrictions on any code. As you said, simply restrict them all.
Click on the pin codes tab and then “Restrict Code”. Do this and set your desired schedule for every code.
