I’m not sure that I understand the problem, but if you don’t want the camera to display within Vera, just remove the IP from the camera device tab or possibly delete the device ???
It returned me a ‘Did not find’ page but I assume this is still ok
However, unfortunately, it seem to slow things down but next morning, the camera was back there
And my ZWAVE network got totally erratic, for whatever reason.
Took me a fully blown factory reset, reprogram etc to get things right.
Anyhow, I circumvented things by parking Vera in a separate WLAN (my guest account) away from the camera and decided to only approach it cia cp.mios.com
Works fine so far.
Leaves the thought that a simple flag to enable/disable any plug in would have simplified life big time.
Maybe in V3?
I’m glad you found a solution for this. Investigating why the blacklistip didn’t work I found that it’s not implemented yet, and probably won’t be in the near future (Mantis #995), given that it has low priority.
