I’m trying to set up a scene with a few minute delay to arm my motion sensors as soon as I leave the house, as the sensors do not reset for a minute or two after I walk by them as I walk out the door. Setting up the scene does have a delay option in Vera but does not seem to work with the scene. Any advice?
if I understand your question correctly it is very simple to set a delay, just create your scene, under “commands” in the box next to your motion sensor choose “unchanged” then in the next box choose your time delay, a third box will appear and there you choose “arm”
Another way to do this is to hit the “advanced” button in the scene…
First add a delay of XXX seconds…
Then add your device with the desired command.
This comes in useful if the exact delay is missing from the other option. You can enter any time in seconds wheras the dropdown box from the other option only allows specific time periods. The advanced option allows more specific control of your device commands as well… hopefully the advanced button will someday include conditional statements.
