Vera sends me push notifications when my door is unlocked and it includes the relevant information (date, time, user, door name, etc) but also has info I don’t need like serial number, alert #, device #.
Is there a way to customize the push notification text to remove some info?
Thanks in advance!
The Vera Alerts Plugin allows you to customize the notifications … but it does not work with MCV’s Vera push notifications.
There are plenty of other Push Notifications schemes out there for Android, IOS, Windows Phone, …
The Vera Alerts Android app allows the alerts to also have 1 of 5 tones and the ability to have the alerts spoken by your phone.
I use the Vera Alerts on my android and it works perfect. I would highly recommend.
Thank you. I should’ve mentioned I use iOS. If Ver alerts plugin doesn’t do push notifications, can you please suggest an alternate for iOS - HomeWave?
Vera Alerts does do push to IOS devices through multiple options including Plugin-Forwarding for HomeWave
See bottom of first post:
http://forum.micasaverde.com/index.php/topic,16490.0.html
Great, thank you. I’m off to dig in deeper…
