I have one of these Vision ZP3111-5 4 in 1 motion sensors. Main task of this guy is to turn on some lights at night when someone is in the office.
it does work, however after a while, the turn off kicks in because the motion detector kinda stops detecting movement, unless you dance in front of it ![]()
My guess is that the sensitivity is to low. However I have no idea how to make it more sensitive?
manual says I should adjust “Parameter 6” to adjust PIR sensor sensitivity, however I don’t exactly know how to do that.
Any tips?
Thanks in advance for your help
