I am a newcomer to ZWAVE and VERA. Just installed my first module yesterday which is the Fibaro roller shutter FGR-222
I would like to configure my system so that the shutter switch (3 state momentary : up/idle/down) will do this:
[ul][li]Single click up : open blind all the way[/li]
[li]Single click down : close the blind all the way[/li]
[li]Double click up : open blind to mid position of 20%[/li]
[li]Double click down : close the blind to mid position of 20%[/li][/ul]
Can this be done?
Do I need to install and use PLEG and PLC for this?
I have 14 shutters in the house and would like to have this set separately for each shutter control device - will I need more than 1 license of these APPs?
and the big question:
Can someone give me a step-by-step explanation of how to do this? or does this info already exist anywhere?
[quote=“toffi77, post:3, topic:195443”]I marked out the lines which have to do with “triple click” since I do not need it right now.
but still did no tmanage to get the switch to react to the double click.
What might I be missing or doing wrong?[/quote]
In case you are still looking for a solution:
[ul][li]Have you enabled the scene controller mode of your Fibaro module (param 50 for FGRM-222)? Out of the box it is not enabled.[/li]
[li]I’m not sure if your device number should be “006” or just “6”[/li][/ul]
