Hi All,
I very recently upgraded to UI5…took a while to get use to it, but i’m persevering.
I’ve been adding a few new devices and playing around with the ‘apps’ section.
I now find that every time i need to make a change to a scene, add plugin etc etc, it takes 3-4 mins for the vera unit to accept the changes.
Firstly i get the ‘Unit Busy’ bar followed by a string of Lua startup notifications. It never took this long in UI4.
The more i play with it each night the longer it takes to complete the ‘save’/‘reload’, to the point where i end up having to re-boot the device every night.
After the reboot it does speed up a bit, but within an hour it gets slower again.
My Z-Wave network has as follows;
23 - Devices - (Mostly dimming switches, mini-motes, and a couple of motion sensors)
6 - Apps/Plugins - (Global Cache, Virtual ON/OFF, Foscam IP Camera, Vera Alerts, Weather App, Sonos Plugin)
17 - Scenes. - (Mostly of activating on/off of lights on time schedules)
So my long winded question is…is this too much for the Vera2 to handle??
Thoughts anyone?
JW
