My Vera3 unit has been mysteriously rebooting/restarting multiple times a day.
I opened a support ticket back with micasaverde on February 2. I’ve had 13 emails flow back and forth during that time period basically with micasaverde asking about when reboots/restarts happen. As support hasn’t really been helpful, does anyone have any suggestions on how to track down this problem? Support asked for when the reboots/restarts happened but that’s about it. The bummer about this behavior is it sometimes happens when I’m trying to interact with my Vera through my iPhone / XBMC box or triggers (unlock a door and expect scenes to happen, etc)
Are you using the ENERGY plugin? it can destabilize your machine?
How many plugins are you keeping loaded/using?
Are you using logging and if so, are you configured to log to a USB?
I am not using the ENERGY plugin
I have the following plugins installed:
SQBlaster Plugin 0.32
Phillips Hue 1.3
XBMCState 1.1
Day or Night 1.1
Program Logic Core 6.3
Program Logic Timer Switch 6.2
dataMine graphing and logging 0.980 [logging to a synology diskstation]
Program Logic Event Generator 6.2
Netatmo 2.20131105
iPhone Detector Plugin 1.71
VeraAlerts 5.2 [how I know it’s rebooting/restarting]
Global Cache GC100 1.0
MIOS Update Utility 1.1
Evolve LCD1 Scene Controller 0.7
ImperiHome 1.0
Logging is configured to USB
I would check your Vera resources, for example your memory. You could be exhausting it and Vera to run out and reboot. You have a lot of plug-ins installed. First check your Vera memory and cpu resources.
- Garrett
the output from top, LuaUPnP is saying 100% of memo but the top line looks like only 50% is used? Rusty on using top…:
Mem: 86172K used, 41284K free, 0K shrd, 16116K buff, 31836K cached
CPU: 5% usr 5% sys 0% nic 87% idle 0% io 0% irq 0% sirq
Load average: 0.33 0.42 0.37 1/104 10494
PID PPID USER STAT VSZ %MEM %CPU COMMAND
10187 2169 root S 124m 100% 2% /usr/bin/LuaUPnP
2078 1 root S 748 1% 1% /usr/bin/luci-bwc -d
21442 2277 root S 6880 5% 0% /usr/bin/NetworkMonitor
10029 10015 root R 1680 1% 0% top
2356 1 root S 4072 3% 0% lighttpd -f /etc/lighttpd.conf
545 1 root S 1928 2% 0% syslogd -C256
2274 1 root S 1792 1% 0% /bin/ash /usr/bin/cmh-ra-daemon.sh
2032 1917 root S 1780 1% 0% /bin/ash /usr/bin/SetupRemoteAccess.s
1917 1 root S 1780 1% 0% /bin/ash /usr/bin/SetupRemoteAccess.s
1934 1 root S 1696 1% 0% crond -c /etc/crontabs -l 5
2169 1 root S 1688 1% 0% /bin/ash /usr/bin/Start_LuaUPnP.sh
1 0 root S 1684 1% 0% init
10015 9805 root S 1684 1% 0% -ash
513 1 root S 1684 1% 0% init
2277 1 root S 1680 1% 0% /bin/ash /usr/bin/Start_NetworkMonito
2109 1 root S 1680 1% 0% watchdog -t 5 /dev/watchdog
10553 10504 root S 1676 1% 0% /bin/sh -c ser2net -n -C "3481:raw:0
2192 2169 root S 1676 1% 0% /bin/ash /usr/bin/Start_serproxy.sh
547 1 root S 1672 1% 0% klogd
So this may just be my experience, but I had some Z-Wave devices that would flood the network causing multiple reboots or sometimes immediately if 2 devices were flooding, but normally after an hour just one device was.
http://forum.micasaverde.com/index.php?topic=23088.0
I have these plugins (plus more you don’t have) that i would vouch as reliable.
Day or Night 1.1
Program Logic Core 6.3 (unless you have something looping, check the PLEG log)
