How else can you combine two Vera edges?
How to see UPnP devices of other Vera edge? How else can you combine two Vera edges?
You can bridge the two controllers, or use a third-party ‘master’, such as OpenHAB or openLuup, running on a separate machine.
А по инструкции , добавление upnp device?
For instructions on bridging, see here:
https://support.getvera.com/customer/en/portal/articles/2949608-q-how-can-i-bridge-two-controllers-
Не видит вторую vera !!!IMG_20190413_111833
“Does not see the second Vera” …
… may be a wrong setting on that Vera, but your best bet now is to reach out to Vera support.
