How can Vera integrate and use the extra storage capacity?
Does anything specifically need to be done for Vera to use the drive besides plugging the thing in? Does it needs to be mounted for the OS to recognize and use it? If so, what command line should I use when I telnet into Vera to mount the drive?
To mount the drive you can use the command:
mount /dev/scsi/host0/bus0/target0/lun0/part1 /mnt/usb
Remember to create the directory /mnt/usb first.
Also if this does not work check the dmesg to verify the OS found the usb stick after plugging it in. It should say something like this:
Manufacturer: USBest Technology
Product: USB Mass Storage Device
SerialNumber: 00000000000208
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: Ut163 Model: USB2FlashStorage Rev: 0.00
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
SCSI device sda: 1974271 512-byte hdwr sectors (1011 MB)
sda: Write Protect is off
Partition check:
/dev/scsi/host0/bus0/target0/lun0: p1
I add the mount command in the start up script.
I also installed SFTP and use a 1GB stick as a convienent, cheap, low overhead FTP server for casual use.
