I’ve installed a few plugins and removed them. I’d like to clean them up. How do you determine which files are a part of a plugin?
Are you using UI5 or UI7?
If you look inside the user_data.json file (Which is a large data structure) you will find which files are associated with a plugin that is downloaded from the APP store … If you just load files … it will not know what they are related to.
You can access the user_data.json file from ssh (you will need to decompress it first) there are threads on this.
Or access it from the browser as:
Using UI7
Rex,
Do the plugins have to be installed to be seen in the file?
Yes, the user_data.json contains ALL of the user specific configuration information … including details about installed plugins.
If you uninstall plugins … the files are left on your Vera … but will not be shown in this file.
Also … standard Vera files will not be listed there.
Thanks Richard
If you have installed all apps/plugins through the App Store and not manually, if you delete them, they will automatically be downloaded on next restart.
Of course manually uploaded files will not.
Brientim - You mean if the plugin is still installed and the files are deleted correct?
If the plugin has been uninstalled deleting the files should work???
Brientim - You mean if the plugin is still installed and the files are deleted correct?If the plugin has been uninstalled deleting the files should work???
Correct … that’s why Vera keeps track of the files for installed plugins … so it can restore them if they are deleted.
Thanks to you both!
