Sorry your experiencing an issue. You definitely are executing them correctly. Basically i save the exact text as a command so typically it just works. Let me take a look and see if there is a possible scenario where i’m not properly updating the voice command list. This is a OS level thing you do that maybe is getting skipped for some reason. I’ll probably be adding some more logging to hopefully see what is going on. Keep an eye out for an update regarding this. Thanks for reporting.
Ya some old beta code was left in that was overwriting the voice command file when the app loaded and was not properly updating the voice commands within it after that. I believe i got it fixed so it will go out in the next update.
