Hoping to figure out how to use PLEG to control dimming of a Fibaro FGD211 per my other thread, and stuck on one part - hope somenone can help!
I have setup a virtual dimmer as a device and I can alter its value in the Vera GUI. I have setup a device “Living Room Spotlights Virtual” input in PLEG to report the value which works ok…
pLivRmSpotDimLvl Living Room Spotlights Virtual LoadLevelStatus 10 (set at 10% in this case)
Through an action, I would like to set the dim level of real device based on the virtual one above. I have tried the following the in the advanced tab of the action…
Delay: Immediate
Living Room Spotlights SetLoadLevelTarget newLoadlevelTarget pLivRmSpotDimLvl
But it did not work, so in the LUUP tab, I tried…
‘Living Room Spotlights’ SetLoadLevelTarget newLoadlevelTarget={(pLivRmSpotDimLvl)} (I also tried without the single brackets)
But it didn’t work either!
Would anyone know what is wrong with this method or syntax, really appreciate it!
