I am a noob with PLEG. I want to turn on and off several Appliance Modules based upon the Temp and Humidity readings from an AEON MultiSensor.
My parameters for Triggers are below.
Triggers
Name Description State Last True Last False
Hum_Hi Humidity reported by _CH_1_Humidity Sensor go above 95 false 0 0
Hum_Low Humidity reported by _CH_1_Humidity Sensor go below 60 true 2015-05-13 21:54:20.102 0
Temp_Hi _4 in 1 sensor (temp) temperature goes above 5 degrees false 0 2015-05-14 13:26:24.965
Temp_Low _4 in 1 sensor (temp) temperature goes below 2 degrees true 2015-05-14 13:26:24.965 0
Thanks in advance
