I’m using an EZLO Plus and the Vera App Version 3.56 (7). I have a motion sensor in our hallway that turns on the lights when someone enters the area. I do this with a Scene named “Hallway Motion Lighting”. Unfortunately, I get a text message every time motion is sensed and again after the time expires and motion is no longer sensed.
On the scene setup, under “Notify users”, I have all three “Select which users will be notified” UNCHECKED.
What else do I need to do to stop getting the notifications???
Tom, I don’t think browsers can work with the EZLO Plus. I’ve been told it can ONLY be done via the app, in my case, iOS. I just tried to log on via my browser (Safari), and it shows the EZLO to be “OFFLINE”.
Hello @k7jv,
Please make sure the motion sensor is disarmed. Otherwise, it will keep sending notifications every time it gets tripped or untripped. You can change this configuration under “My Preset Modes”. To do this go to the VeraMobile app → “Dashboard” → tap the House Mode icon → “Configure” → uncheck your user under “Who should be notified?”
Regards!
