As seen in this screen shot…I uninstalled the energy plugin but these “0w” are still there.
Have you tried to refresh and clear your browser cache with ctrl f5 or something similar?..Failing that a refresh of the Lua engine or vera restart?
I had this sort of thing before with battery and wattage indications, where some battery devices report wattage and some non-battery devices report a battery level, and if I manually delete the wattage values from within the advanced tab of the devices that have it, and save again, that works for me!
Thanks…clearing the 0 out of each one manually did the trick.
Your the MAN
