Hello
This is my first time posting, so please excuse the basic question here. I am having issues with setting up the DSC alarm System plugin with my envisalink SDS. I have everything set up correctly physically and am getting texts from envisalink, etc.
I have seen on this site that I need to tell it to use access port 4025 and choose the envisalink over IT 100, but what is my IP address? Is there some walkthrough that someone has posted that I can’t find?
Thanks!
From the manual:
LOCAL ACCESS
- To access the web interface on the module, from a browser on the same internal
network type “envisalink” or the IP address of the module.
- The default user name is “user” and the default password is “user”
Sometimes the router will report the ip address of the dhcp clients. Have you logged into your router to check if there is any such list?
In any case, it should be set either to a static IP, or a reserved one through the router anyway.
the free iphone app called fing is great for finding lan ips.
