Hi
i’ve installed a couple of modules to control blinds and lights.
I created a scene that shuts off all the lights and closes all the blinds.
i want to activate this scene using a switch near my bed.
can it be done? how?
thanks.
Hi
thanks.
This is a question that gets asked often. In order for this to work you need a switch that supports instant status. What type of switches did you install?
i currently have gewiss switches installed but i dont mind having another switch for this purpose alone.
You don’t say where you are?
If in the UK/EU then you can use a qubino flush 1 switch which has additional inputs for scene control.
Elsewhere I have no idea who has a module that supports additional inputs.
I use EU vera. bought in Uk.
isn’t this behavior supported in fibaro relay?
must I buy a qubino flush 1 switch?
