I’m a Zwave/Vera newbie, using Vera in conjunction with INDIGO/INSTEON.
As I’m making headway, I want to do more ![]()
I have On Time set to 10 minutes. All working well.
Occasionally I turn the light off manually and if I do that inside the 10 minutes I can’t re-enter the room and get lights.
What I’d like to do is send a command to the motion sensor to set it back to Armed, not tripped when I turn the light off manually.
Any help greatly appreciated.
