Hi
I have VeraLite it is comes with 1.5.622 Firmware
I want to change Device Type how can I do that
please look at Attachment
Thanks a lot
Hi
Thanks a lot
You can’t. Previous discussion: http://forum.micasaverde.com/index.php?topic=12368.0
It looks like it is now possible to change the device type, has anyone tried this approach?
Did it for my siren and it work just fine…
You should heed the advice from @futzle
Changing the device type effects more than just the ui (icons and buttons.)
There are a few cases where this is possible (i.e. changing from one sensor type to another, where the device API is the same for the different sensors).
But only the developer of the controlling device can tell you for sure … and in the case of Z-Wave devices … MCV is the developer for the controlling device (the Z-Wave controller).
If the device type is wrong … you need to report this to MCV and wait for them to fix it!
