I’d like to count multiple button pushes and then enable a scene dependent up the count. Does anyone have a snippet of LUA/LUUP code they are happy to share to get me started? Ive been trying but not getting anywhere fast.
Many thanks
Many thanks
[quote=“col8eral”]I’d like to count multiple button pushes and then enable a scene dependent up the count. Does anyone have a snippet of LUA/LUUP code they are happy to share to get me started? Ive been trying but not getting anywhere fast.
Many thanks[/quote]
First you have to have a switch that supports instant status. Otherwise Vera will not see all the events. Even with instant status you need to not switch faster than one on/off cycle per second.
You can use the PLEG multi-click operator as follows.
Switch @3 < 30
Which is true if the switch is turned on three times in 30 seconds.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thanks Richard
Can this be done in LUA / LUUP also?
The button I was thinking of is a Nodon Octan. I need to check if it supports instant status.
