Hello,
I am setting up my vera+ ( came from UI5) and I want a notification on a scene after 5 minutes. The same procedure I used as on UI5 , but I see a third option: “Housemodemask”.
What do I insert there , or what are the options?
Thanks ,
Cor
Hello,
Thanks ,
Cor
I use the Countdown Timer plug-in to delay notification for 1 minute that the front door is open when in Home mode. That allows me time to get the paper in the morning or my wife to check the front porch at night.
In the advanced tab you can insert a notification with a time dealy when you select “vera alerts”> send message. Works very good. But now , when I upgraded I have now an extra option “housemodemask” but no idea what it means or what to insert.
thanks,
Cor
Leave it alone … it will send the message in any UI7 House mode.
Otherwise you can setup some alerts to only be sent when you are HOME, AND/OR AWAY, AND/OR on VACATION, AND/OR when you it is NIGHT.
ohhh … I see.
Many thanks
Cor
