Hi All, I am fairly new to this and trying to get the house mode plugin to change from mode “away” to either “day” or “night” when I come home based on whether it is actually day or night.
For example, If I’m away and I come home at night time I want the house mode to change to “night”, but if i come home during the day I want it to switch to “day”.
At the moment I have it setup with 2 scenes, each scene has some code in them. Both scenes trigger when I disarm the alarm but I only want one of them to run. Despite having the code in each of them they both still appear to run.
Totry and stop one of the scenes from running if it is night time I have used:
if (luup.is_night()) then
return false
And to stop the other scene from running during the day I have used:
return true
else
return false
Despite this they both seem to be running when looking at the scenes last runtimes in the UI and the mode that the system switches to seems to differ
Does anyone have any ideas as to where I may be going wrong? Or is there a better / easier way to do this with one scene or one lot of coding?
I have this plugin but if I use this as a trigger for a scene it will trigger every time the Vera switches between day and night given you can’t use multiple triggers in a scene
Tried to use multiple triggers with AND in a scene and no matter what I tried I couldn’t get the scene to execute once I added a second trigger and set it as AND
Anyone else have problems trying to use multiple triggers with AND?
If I remember correct I think I had problems when editing existing scenes, try to create a new one strictly from the app (and don’t even edit it in a browser afterwards). Also toggle all the switches including in the scene at least once before it runs on a schedule.
