I have a Honeywell YTH8320ZW1007 thermostat. I have it programmed schedule for wakeup, leave, return, sleep. I use Vera,ite, ui7, to manually change the temp. This puts the thermostat to hold, manual, mode. How to switch it back to schedule mode from Vera?
check out this forum conversation. http://forum.micasaverde.com/index.php/topic,30125.60.html. JoeyD has developed a great plugin for the Honeywell thermostats and will be using the Energy button for the schedule and the Normal button to go back to hold in his next release.
