So I’m considering the Honeywell YTH8320ZW1007 zwave thermostat, Is there a pluggin needed for this? I ultimately want to be able to Shut off / Turn On / set temp through vera while away.
Thanks!
Thanks!
No plugin is needed for a Z-wave thermostat.
@RichardTSchaefer - Can you control ON / OFF and adjust temps via VERA with a zwave honeywell thermostat?
Yes
