I am having an issue after the UI7 upgrade where I can no longer see Auto in the UI. I only see Cool or Heat. Does anyone know how to fix this?
I don’t have a Honeywell, but on the dashboard there is no auto shown, but if I click the arrow to go to the device, it is there. Hope this helps
I have them. I noticed that as well. The Auto function does not show on the dashboard. It would be nice if it were added back. Also, if you have it set to Auto, you no longer have the ability to add a setpoint for cool and heat. You only have one setpoint now. Can we get this resolved? Also, the interface displays NaN for the temp. I assume it is because I have them set to auto and there are two setpoints active.
Have you seen this post?
