Honeywell T6 Zwave Tstat
Are there any plans for the interface in mios for the Honeywell T6 Thermostat in mios to be updated?
The Vera app displays the humidity with the temperature. Mios doesn’t.
Also my old Honeywell thermostat Interface displayed the system status - ie actively heating or cooling.
Bill
Since the firmware update, control of my T stat is intermittent. The geofence triggers, but it doesn’t set correctly sometimes. It seems I can’t use either mios or Vera apps for control either. It’s hit and miss. I usually end up having to go manually set the T stat
All of the gui’s have issues. They will randomly set the temp to something crazy (99F). I couldn’t figure out why it was so hot in here till I looked at the thermostat
Hello @BillC
Could you please share your MiOS app version? You can find it under More → Help.
Based on the icons in your screenshot, it seems that your app is not up to date because it should look like this:
Thank you!
Could you please try logging out and reinstalling the app?
Deleted and reinstalled. I’ll report back
Still wacky. It is not setting correctly. I set it to 76
I can’t reliably set the thermostat with anything- mios,Vera, ezlogic now
Geofence set it to 99 Instead of 76
Hello @BillC,
In that case, we will create a support ticket to check your controller and share the solution here later. Please check your inbox in a couple of minutes.
Thanks for the assistance
Any word on the progress ?
Bill
Hello @BillC
Unfortunately, not yet. Let me check with the developers, and I will update you.
Anything from the Devs?
Bill
