I did use the MIOS Honeywell Lyric Round plug-in (Device\Thermostats) to connect my Vera Edge to my Honeywell Lyric T6 WiFi thermostat , which does control my heating at home.
The child device displays the values (CurrentSetPoint, CurrentTemperature etc.) from the thermostat as should, but I do have problems when I want to change temperature .
When I update the Setpoint using the webconsole (screencopy) with the arrow buttons, it returns the error: Heat setpoint value cannot be greater than Cool setpoint (10) .
I am use only 2 modes (Off,Heat) , so not sure where this comes from
I solved this issue by putting my D6 pro to Heat mode and then setting the heat temp to 18c. Once I did this I could set a Cooling temp down to 18c.
Why this stupid limitation is built into the MIOS Lyric Plugin is totally beyond me, it not a Honeywell limitation as I’ve tested it using just the Honeywell app and it doesn’t care what the set-points are for non-active modes.
