Does the Honeywell Lynx Touch L5100 give you the option to use existing wired sensors as well, if so can these inputs be used with vera? I looked all over and it seems it is just the zwave/wireless sensors. Correct me if I am wrong. I am looking for a system I can integrate with the existing system I have. I do not mind changing the brain/controller of the system. Thanks in advance.
I just installed the 5100 and you can only have 1 hardwired sensor.
