When running the Honeywell YTH8320ZW1007 in Celius the increments are by .5 degrees. Eg. mine is set to 23.5c
Is there anyway to display the proper temp on the web or phone interfaces ? Mine always just shows up as 24c even though its 23.5c ???
Welcome to the forum. This is a known problem and is discussed in many threads on this forum. I recommend that you search the forum for your questions before posting. But to answer your question, Vera will only present integers not decimal values for z-wave type devices. Plugins that are developed by 3rd parties may display their values with decimals. This was brought up with MCV many times.
