Yes, it’s possible. There is a learning curve for you. You’ll need a mix of the following skills:
[ul][li]Find and understand existing working examples. I recommend the Virtual Switch as a starting point. Install the plugin and look at the plugin files it adds to your Vera.[/li]
[li]Read the wiki documentation and figure out which of it is still correct.[/li]
[li]Persevere when you get stuck, and know when to ask for help on the forum.[/li][/ul]
[quote=“futzle, post:3, topic:179840”]Yes, it’s possible. There is a learning curve for you. You’ll need a mix of the following skills:
[li]Persevere when you get stuck, and know when to ask for help on the forum.[/li][/ul][/quote]
Yes its a learning curve I know.
I got it working already
I managed to ad a trigger to the “virtual” switch so now i can turn light off and on. lower my screens … etc
Now im trying to find a way to make a slider to use my kaku dimmers ?
and thnx for the extra information. Lots to learn and lots to read…
