Does HomeWave work on cellular…when WiFi isn’t available? I can’t seem to get it to!
It should.
Make sure that in Settings (on your iPhone settings not in the app) is setup with your MiOS username, password, Device ID etc. The IP address should be your LAN address, FYI.
if you are using UI6, I’m not sure it is working there, yet.
UI6 is not supported on cellular networks yet! It will work just fine on WiFi, though.
Okay, it seems to be working on cellular now. It’s strange, yesterday and today I tried accessing via cellular while sitting on a plane during boarding and it didn’t work. But shortly after I would try on WiFi and it was fine. But right now it is working on cellular.
