How can I select the preset modes in UI7 with Homewave? I know I can create scenes with the same names and perform the same actions but was wondering if there was a way to call the preset modes.
Add a Multi Button and link it to your Vera
perfect. Thanks!
Is there a way to set a specific mode with an action button? I can’t seem to get that to work.
Necrothreading as I had the same question.
Multi Button is a control in HomeWave that you add like a device. When you add it, you can select the device it controls. Choose your Vera, and it gives you buttons for those modes.
You can, if you put in the current LUUP fragment to set the mode. I’m not sure what that is; I’d have to look it up
