HomeWave 2.16 has been released. This is mostly to fix the issue with crashes on iPads running iOS 14
There is a new Maintenance screen, which you can access from Settings → Info → Maintenance (it will move to another menu later). This will show all devices that Vera reports as having problems: no connection, or low / no battery, giving you a quick overview of devices that need attention.
Keep in mind that this is still somewhat experimental! I’d like to know what else you would like to see on this screen.
